This program is great but there are a few things I can do in Finder that I can not do with XNview that I need to be able to do to make it functional.
I need to put the file name only in excel sheets . In Finder i can select several images ctrl+c and ctrl+v but in here I must go to the menu and click copy to clipboard.. file name. How can I make that my default ctrl+c?
Also how I can delete with a short cut key? When I hit delete it takes me out of the folder?
Thank you
Copying multiple file names & delete short cut key
kona-kat
