0.91 beta 1 - Export dialog - WebP - compress to filesize
masterjp
Post by masterjp »
First I want to thank you for the great update! Many functions were improved and errors were fixed. :-)
In the export dialog I took the WebP format and tried to compress to filesize.
XnView MP ignore the desired filesize (512kb) and use the quality setting (75) to show the estimated filesize.
The saved pictures file is as big as the preview shows (1.08 MB).
Re: 0.91 beta 1 - Export dialog - WebP - compress to filesize
i've tried with cwebp -size, and output size doesn't reflect parameter
masterjp
Post by masterjp »
Sorry, I did not understand, what you want to say.
masterjp wrote: Fri Jun 29, 2018 5:45 pm Sorry, I did not understand, what you want to say.
the command line tool has the same problem
masterjp
Post by masterjp »
It is a pity, but okay.
