Automatisation
pmarchal
Automatisation
Post by pmarchal »
I have 6500 pictures in ECW format (orthophoto) and I need to merge them on mosaic of 25 images (5X5). With XnView, it's possible to make a panorama in height and width. But, my system is busy when I try to merge only 2 file (process xnview.exe = 380 Mo in memory), I work under Windows 2000, Pentium 4, 512Mo RAM. Under Linux, ECW is not supported.
So, is it possible to make a script which do the work I want? I try to start xnview in a .bat file, it doesn't work. Other scripting methods can help me (in some xnview's screens, I can see "save the script" or Nconvert).
Thank you for your help
Anika
Post by Anika »
If your pictures are all the same orientation and ratio, just mark all images and select create contact sheet. Now just calculate or try the desired values.
I hope this helps.
Greetings, Anika
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
