Cannot rename the pages by the right order.
sugar39
Post by sugar39 »
Hi every one,
Why these page's name in my folder aren't the same as their own name when i drop them in Xnconvert. Because of this case, i cannot rename them by the right order. Can someone show me how to fix this problem?
Please tell me the way to solve them.
Tks all.
Re: Cannot rename the pages by the right order.
sugar39 wrote: Sun Jun 17, 2018 4:25 pm Why these page's name in my folder aren't the same as their own name when I drop them in XnConvert. Because of this case, I cannot rename them by the right order. Can someone show me how to fix this problem?
I'm not clear what determines the sort order when files are loaded into XnConvert, but I've noticed that clicking on the Name tab above the files in the Input window changes the sort order, so you could try that pending a possible better response from Pierre...
Otherwise, the full filenames of your files aren't visible in the left screenshot, so it isn't possible to work out what exactly is happening; you may possibly need to rename (copies of) your files using renaming software, if the desired sort order can not be obtained in XnConvert.
