XnView: MP 0.90 - 32-bit
OS: Windows 10 - 64-bit
Effect: dpx file viewed incorrectly
dpx viewed incorrectly, probably because of non-standard width and height(1911x1063). Same image but 1920x1080 views fine.
1. download and open dpx file https://www.dropbox.com/s/2wl7ss4453zip ... t.dpx?dl=0
Actual behaviour (bug):
Expected behaviour:
0.90: dpx viewed incorrectly
dead_vip
Re: 0.90: dpx viewed incorrectly
which software has created this dpx file? this file doesn't padding, but i have file that use it
perhaps i need to add a settings...
dead_vip
This file generated with proprietary software(implemented by me). Yes there is no padding, however there is no requirement to add padding in dpx specification so I think viewers shall display file without padding correctly. Btw ffmpeg views this file correctly.
