[Resolved] Move Folders
JamesGT
Post by JamesGT »
Never mind, I figured it out. :)
Re: Move Folders
JamesGT wrote:Never mind, I figured it out. :)
I guess you figured out that currently moving folders is not possible in XnView. You can move or copy images, only.
There's a workaround suggested by Olivier, see topic "Move or copy to new folder".
Dreamer
Re: Move Folders
Post by Dreamer »
But it IS possible! Copy/move with drag&drop, context menu and Ctrl+X/C/V shortcuts (from v1.80 I think). :?
Re: Move Folders
Oops, right: You can move folders from file list to anywhere in the folder tree by dragging & dropping.
But: You cannot move folders in the folder tree, only. (In my file list folders are excluded and thus not shown, this is why I cannot move them.)
Perhaps a good addition to support folder operations in folder tree.
JamesGT
Post by JamesGT »
I can move any folder anywhere. I just drag and drop it from the right side to the left side of the window.
My problem was XNVIEW wasn't showing me the folders in the image window on the right. I had to activate that option for Thumbnail view and now it works great!
