Video Files don't reload in preview pane after renaming
Brother Gabriel-Marie
Post by Brother Gabriel-Marie »
Say you are in browse mode with the preview pane open.
You click on an mp4 file, and the video loads in the preview pane.
Now you use F2 to rename the file. The file is renamed,
however, the preview pane unloads, and even though the file is selected, it does not reload in the preview pane.
To get it to reload in the preview pane, you have to select a different file, then reselect the original one.
