How to run flatpak GIMP 2.10
Over60
Post by Over60 »
I wonder how it is possible to open an image from within xnview like "open with GIMP 2.10".
My GIMP is a flatpak installation on Linux Mint 18.3
Xnview wants a programme to be entered in the settings but how would I enter stuff like this?:
/usr/bin/flatpak run --branch=stable --arch=x86_64 --command=gimp-2.10 --file-forwarding org.gimp.GIMP @@u %U @@
(That's the menu entry)
Regards
Over60
XnViewOnLinux
Re: How to run flatpak GIMP 2.10
Post by XnViewOnLinux »
I just found your post after asking the same question. Since you haven't received a single answer in over a year, I'm guessing the XnView developer doesn't know how to do it. Either way, it would be nice if the dev would at least reply and let us know the status.
Over60
Post by Over60 »
I still haven't found a solution yet.
After all I upgraded my sysetm so I can use a normal GIMP PPA.
Still there is a glitch with xnview: GIMP crashes when using clipboard functions when xnview is open at the same time.
XnViewOnLinux
Over60 wrote: Mon Nov 18, 2019 2:42 pm I still haven't found a solution yet.
Which version of GIMP crashes? 2.8 or 2.10? I had constant headaches with GIMP 2.8 crashing when trying to copy & paste images or layers. I never even considered it might have something to do with XnViewMP, but I almost always have it open on a secondary monitor.
Over60
Post by Over60 »
I'e encountered this with GIMP 2.10 on a linux mint system
RayCulp
Post by RayCulp »
This question is old, but it hasn’t been answered yet, so here is a workaround that works for me.
Create a bash script with the following command:
#!/bin/bash
flatpak run org.gimp.GIMP "$1"
In XnView, configure a new "Open with" program that points to this script. The path to the script is sufficient. No additional arguments need to be provided.
I hope this helps.
If Program.IsBroken Then
   Program.Debug
Else
   Program.DoNotTouch
EndIf
