- Having copied images from my smartphone (with a cable), the file time is preserved in the copy (which would not be the case if copying through a utility using an internet connexion).
- But XnView displays the ctime of the files instead of the mtime (although it does display the correct time from the Exif information).
- This seems to be a bug, as the ctime reflects the time the files were copied, not the initial time of the files themselves. Xnview should display the mtime, as does any file explorer or ls command.
displaying file time in Linux
silvain
I am discovering a strange behaviour of XnView explorer in Linux :
Re: displaying file time in Linux
where is displayed the ctime?
