[0.91b3]Recursive view deletes recent searches
jadO
Post by jadO »
1. Open folder in explorer view
2. Select Show files in subfolder
3. Perform some searches via quick search
4. Verify that quick search has rembered the searches as recent searches
5. Deseleect recursive view
6. Check recent searches
Outcome: Recent search has been cleared. I think recent search should be remembered.
Re: [0.91b3]Recursive view deletes recent searches
currently history is cleared when folder view is changed (folder, recusrsive)
jadO
Post by jadO »
xnview wrote: Mon Aug 06, 2018 11:37 am currently history is cleared when folder view is changed (folder, recusrsive)
I don't think search history should be cleared. Why? Because I use it for some regex sometimes and its not funny when the regex is suddenly gone.
I even think recent search history should get saved on close application so it is remembered between sessions,
But there should be an option to delete specific searches selectivley.
so when you change folder, no clear?
jadO
Post by jadO »
xnview wrote: Mon Aug 06, 2018 12:17 pm so when you change folder, no clear?
Yes.
