XnView MP Windows 10
Version 0.90 64bits (Mar 4 2018)
Libformat version 7.16
Hello, in XnView when i am in Explorer tab i see folders and files, i mouse left click one file and do Ctrl+X (to "cut" the file), then i right click a folder (in same directory as the file) and select to Paste.
But it prompt saying the file exist - because it is pasting to same/current directory not the one i right clicked and selected for pasting.
When i cut some file in WIndows Explorer and right click folder in XnView MP to paste it, it also pastes in current folder not the folder i right clicked for pasting.
Pasting file into folder does not working when doing via right click
postcd
Linux user, .deb package. Use private services like Proton.me, not surveillance services like Google, Meta.
Re: Pasting file into folder does not working when doing via right click
in xnview.ini, change
pasteIntoSubfolder=true-
postcd
Thank you.
I think this should be working by default. Because i think when i target some directory by right click it, it should be pasted into it.
Octopuss
I was just about to file a bug report about this and then found this thread.postcd wrote: Thu Aug 09, 2018 1:06 pm Thank you.
I completely agree with you, and I strongly believe this option shouldn't even exist in the first place. Everyone expects standard Windows behaviour.
