XnViewMP How to install the beta?
mrwul
Post by mrwul »
Sorry ... dumb question ...
I never used beta versions of XnViewMP.
Have downloaded v.0.91 beta just now (zip), but any suggestion as to how I should install it?
Thanks!
Re: XnViewMP How to install the beta?
sorry but there is no version of beta for linux. The final release will available in 2 weeks...
mrwul
Post by mrwul »
xnview wrote: Tue Aug 14, 2018 1:46 pm sorry but there is no version of beta for linux. The final release will available in 2 weeks...
Sorry, I meant Windows.
I have unzipped the Windows beta .zip file. But now what?
If I copy all the files over the existing XnViewMP files, I guess my settings are gone, right?
unzip the beta, and start xnviewmp.exe (your settings will be kept)
mrwul
Post by mrwul »
Eh.... just to make sure ...
the .zip file is unzipped in D:\Downloads
the installed version is located in D:\XnViewMP-x64
If I run XnViewMP.exe in D:\Downloads, will it then use the settings of XnViewMP from D:\XnViewMP-x64 ?
your settings are saved in User?
mrwul
Post by mrwul »
No, in D:\XnViewMP-x64
in this case you need to rename old version
mrwul
Post by mrwul »
Thanks. I think I will wait for the final version then.
Keep up the good work.
MARK2580
Post by MARK2580 »
Even more stupid question, where can I download 0.94 beta? There is a whole section on the forum called the 0.94 beta test, but there is no link anywhere. I have been waiting for a single fix for a long time, for more than a month. :?:
ckit
Post by ckit »
Pierre, will release it when he's ready just be patient
