Importing large number of images
elfroggio
Post by elfroggio »
XnViewMP 0.90 on Manjaro
I have 281 directories to import: 50 000 images. They all "hang" from a second drive and are below: /drive-b/photos
What's a good way of importing the 281 directories in XV?
I'd rather not have to click on every single directory.
Thanks
Syv
Re: Importing large number of images
Post by michel038 »
before beginning
-check the first "import" option in tools, settings, metadata
-create at least one category
I know two methods, I would like Pierre tell us which is the best one
1 : In folder pane, right click on the parent folder, choose "display all files recursive" . Select all (Ctrl a), click "update catalog from files" in "View" menu
2: Other way, Tools, settings, catalog : use "Add files folders" button
only picture files?
elfroggio
Post by elfroggio »
xnview wrote: Tue Aug 28, 2018 3:32 pm only picture files?
Yes:
cr2
dng
raf
tiff
pef
and there xmps
Thanks
Syv
when you use Settings>catalog>add folder.., XnView MP hangs?
elfroggio
Post by elfroggio »
xnview wrote: Sat Sep 01, 2018 3:22 pm when you use Settings>catalog>add folder.., XnView MP hangs?
No, but I now have 283 (up from 281) folders and I don't want to do them one by one.
After the first time, I don't want to have to remember which new folder I created or if I added some photos to existing folders
Thanks
Syv
Post by michel038 »
You would like xnview to monitor hdd activity like Picasa, isn'it ?
