PngOut.exe - Flagged as Unsafe By Dell Advanced Threat Prevention
tdhca-eddie
Post by tdhca-eddie »
Cylance flags the pngout.exe included in v2.46 as being "bad" whereas the v2.45 release did not cause this to happen. Looks like 95% of customers of Cylance are placing this file in quarantine. Were there any changes made to this program in the recent release? Can you verify the SHA256 hash to confirm that the installer I obtained was the same one you posted?
https://www.virustotal.com/en/file/843f ... /analysis/ - SHA256 hash uploaded here
"This object may contain modifiable code and implies that the object was built using a non-standard compiler or was modified after it was originally built. While some organizations may create and use software built using these techniques, this is not the industry standard."
"This object imports functions that can modify the memory of a running process. Malware does this to inject itself into running processes. By injecting into a process, malware could copy something to memory (like a dynamic link library or DLL) and instruct the process to execute it."
Re: PngOut.exe - Flagged as Unsafe By Dell Advanced Threat Prevention
it's the same as previous version, the sha256 is good
