v0.91 Debian package doesn't work
djcj
There's a missing library:
/opt/XnView/XnView: error while loading shared libraries: libQtAVWidgets.so.1: cannot open shared object file: No such file or directory
Hint: you can use the command ldd to check how the dependencies are resolved before creating a package.
Re: v0.91 Debian package doesn't work
please re-download the package...
djcj
Still missing something:
Like I said, use ldd to figure out the dependencies:
Now you can see which libraries are missing or loaded from the system instead of the opt directory. If you insist on certain libraries to be present on the system, use the Debian package dependencies for that.
$ xnview
/opt/XnView/XnView: error while loading shared libraries: libva.so.1: cannot open shared object file: No such file or directory
djcj ~ $ cd /opt/XnView/
djcj /opt/XnView $ export LD_LIBRARY_PATH="$PWD/lib:$PWD/Plugins"
djcj /opt/XnView $ export QT_PLUGIN_PATH="$PWD/lib"
djcj /opt/XnView $ ldd ./XnView
linux-vdso.so.1 (0x00007ffe5a5ec000)
libQt5MultimediaWidgets.so.5 => /opt/XnView/lib/libQt5MultimediaWidgets.so.5 (0x00007fbcd90f8000)
libQt5Multimedia.so.5 => /opt/XnView/lib/libQt5Multimedia.so.5 (0x00007fbcd8dee000)
libQt5Widgets.so.5 => /opt/XnView/lib/libQt5Widgets.so.5 (0x00007fbcd85ba000)
libQt5Gui.so.5 => /opt/XnView/lib/libQt5Gui.so.5 (0x00007fbcd7e09000)
libQt5Network.so.5 => /opt/XnView/lib/libQt5Network.so.5 (0x00007fbcd7a77000)
libQt5Core.so.5 => /opt/XnView/lib/libQt5Core.so.5 (0x00007fbcd733a000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fbcd711b000)
libQt5PrintSupport.so.5 => /opt/XnView/lib/libQt5PrintSupport.so.5 (0x00007fbcd6ead000)
libQt5Svg.so.5 => /opt/XnView/lib/libQt5Svg.so.5 (0x00007fbcd6c58000)
libQtAVWidgets.so.1 => /opt/XnView/lib/libQtAVWidgets.so.1 (0x00007fbcd6a2a000)
libQt5WebKitWidgets.so.5 => /opt/XnView/lib/libQt5WebKitWidgets.so.5 (0x00007fbcd67e2000)
libQt5X11Extras.so.5 => /opt/XnView/lib/libQt5X11Extras.so.5 (0x00007fbcd65de000)
libQtAV.so.1 => /opt/XnView/lib/libQtAV.so.1 (0x00007fbcd6193000)
libQt5Concurrent.so.5 => /opt/XnView/lib/libQt5Concurrent.so.5 (0x00007fbcd5f8c000)
libQt5Xml.so.5 => /opt/XnView/lib/libQt5Xml.so.5 (0x00007fbcd5d52000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fbcd5b4e000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fbcd5816000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fbcd5488000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fbcd50ea000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fbcd4ed2000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fbcd4ae1000)
libpulse-mainloop-glib.so.0 => /usr/lib/x86_64-linux-gnu/libpulse-mainloop-glib.so.0 (0x00007fbcd48dc000)
libpulse.so.0 => /usr/lib/x86_64-linux-gnu/libpulse.so.0 (0x00007fbcd468c000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007fbcd4376000)
libQt5OpenGL.so.5 => /opt/XnView/lib/libQt5OpenGL.so.5 (0x00007fbcd411e000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007fbcd3e92000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fbcd3c75000)
libicui18n.so.56 => /opt/XnView/lib/libicui18n.so.56 (0x00007fbcd37dc000)
libicuuc.so.56 => /opt/XnView/lib/libicuuc.so.56 (0x00007fbcd3424000)
libicudata.so.56 => /opt/XnView/lib/libicudata.so.56 (0x00007fbcd1a41000)
libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007fbcd183f000)
/lib64/ld-linux-x86-64.so.2 (0x00007fbcd9316000)
libXv.so.1 => /usr/lib/x86_64-linux-gnu/libXv.so.1 (0x00007fbcd163a000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007fbcd1428000)
libQt5WebKit.so.5 => /opt/XnView/lib/libQt5WebKit.so.5 (0x00007fbcceed6000)
libQt5Sensors.so.5 => /opt/XnView/lib/libQt5Sensors.so.5 (0x00007fbccec96000)
libswresample.so.3 => /opt/XnView/lib/libswresample.so.3 (0x00007fbccea7c000)
libavfilter.so.7 => /opt/XnView/lib/libavfilter.so.7 (0x00007fbcce826000)
libva.so.1 => not found
libavcodec.so.58 => /opt/XnView/lib/libavcodec.so.58 (0x00007fbccdbf4000)
libavformat.so.58 => /opt/XnView/lib/libavformat.so.58 (0x00007fbccd8ce000)
libswscale.so.5 => /opt/XnView/lib/libswscale.so.5 (0x00007fbccd658000)
libavutil.so.56 => /opt/XnView/lib/libavutil.so.56 (0x00007fbccd405000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fbccd1dd000)
libpulsecommon-11.1.so => /usr/lib/x86_64-linux-gnu/pulseaudio/libpulsecommon-11.1.so (0x00007fbcccf5f000)
libdbus-1.so.3 => /lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007fbcccd12000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007fbcccaa0000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007fbccc86f000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007fbccc5b9000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fbccc3b1000)
libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007fbccc1a7000)
libXcomposite.so.1 => /usr/lib/x86_64-linux-gnu/libXcomposite.so.1 (0x00007fbccbfa4000)
libsqlite3.so.0 => /usr/lib/x86_64-linux-gnu/libsqlite3.so.0 (0x00007fbccbc9b000)
libQt5Positioning.so.5 => /opt/XnView/lib/libQt5Positioning.so.5 (0x00007fbccba3f000)
libQt5Quick.so.5 => /opt/XnView/lib/libQt5Quick.so.5 (0x00007fbccb406000)
libQt5Qml.so.5 => /opt/XnView/lib/libQt5Qml.so.5 (0x00007fbccae06000)
libQt5WebChannel.so.5 => /opt/XnView/lib/libQt5WebChannel.so.5 (0x00007fbccabe8000)
libQt5Sql.so.5 => /opt/XnView/lib/libQt5Sql.so.5 (0x00007fbcca9a1000)
libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007fbcca791000)
libva-drm.so.1 => not found
libva-x11.so.1 => not found
libvdpau.so.1 => /usr/lib/x86_64-linux-gnu/libvdpau.so.1 (0x00007fbcca58d000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fbcca389000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fbcca183000)
libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007fbcc9eff000)
libwrap.so.0 => /lib/x86_64-linux-gnu/libwrap.so.0 (0x00007fbcc9cf5000)
libsndfile.so.1 => /usr/lib/x86_64-linux-gnu/libsndfile.so.1 (0x00007fbcc9a7c000)
libasyncns.so.0 => /usr/lib/x86_64-linux-gnu/libasyncns.so.0 (0x00007fbcc9876000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007fbcc9661000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007fbcc943b000)
liblz4.so.1 => /usr/lib/x86_64-linux-gnu/liblz4.so.1 (0x00007fbcc921f000)
libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007fbcc8f04000)
libnsl.so.1 => /lib/x86_64-linux-gnu/libnsl.so.1 (0x00007fbcc8cea000)
libFLAC.so.8 => /usr/lib/x86_64-linux-gnu/libFLAC.so.8 (0x00007fbcc8a73000)
libogg.so.0 => /usr/lib/x86_64-linux-gnu/libogg.so.0 (0x00007fbcc886a000)
libvorbis.so.0 => /usr/lib/x86_64-linux-gnu/libvorbis.so.0 (0x00007fbcc863f000)
libvorbisenc.so.2 => /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2 (0x00007fbcc8396000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007fbcc817b000)
libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007fbcc7f66000)
djcj
I did some checks and it turns out you can install all the Qt libs through the dependencies. This will reduce the package size to 12 mb.
Here's the dependency line:
You can easily build such a package yourself:
Package will be in $HOME/buildresult.
By the way IlmImf.so (which just seems to be a renamed libIlmImf-2_2.so.22 file) isn't listed among the plugins when I go Info->About->Plug-Ins.
Depends: libc6 (>= 2.17), libgcc1 (>= 1:3.0), libilmbase12, libqt5concurrent5, libqt5core5a, libqt5gui5, libqt5multimedia5, libqt5multimediawidgets5, libqt5network5, libqt5printsupport5, libqt5svg5, libqt5webkit5, libqt5widgets5, libqt5x11extras5, libqt5xml5, libqtav1, libqtavwidgets1, libstdc++6 (>= 4.8.1), libx11-6, zlib1g, perl:anyCode: Select all
git clone https://github.com/darealshinji/debian-packaging
cd debian-packaging/graphics/xnviewmp && makeBy the way IlmImf.so (which just seems to be a renamed libIlmImf-2_2.so.22 file) isn't listed among the plugins when I go Info->About->Plug-Ins.
djcj
I see that the libqtav packages are not available on older distros. But you should better check the package in a clean environment (i.e. VirtualBox) to see if it really works without problems.
edit:
Another side-note: in xnview.sh you should always keep the old PATH environment variables:
should be
edit2:
I've changed my build files on Github to keep the bundled libraries in the package.
edit:
export LD_LIBRARY_PATH="$dirname/lib:$dirname/Plugins"
export QT_PLUGIN_PATH="$dirname/lib"Code: Select all
export LD_LIBRARY_PATH="$dirname/lib:$dirname/Plugins:$LD_LIBRARY_PATH"
export QT_PLUGIN_PATH="$dirname/lib:$QT_PLUGIN_PATH"I've changed my build files on Github to keep the bundled libraries in the package.
xnviocumo
In kubuntu 18.04, xnview v0.91 (installed from the x64 deb package) also fails with:
...and
as a consequence of what @djcj has explained so very detailed (thanks a lot for this valuable help, djcj).
I would like to contribute to help those who come to this thread and don't know what to do other than wait for the fix. This is how I made it work --at least for now.
WORKAROUND
Note that this is not a final solution, it is just a hack to get you working until a fix is posted.
Basic background (you can just skip this part and go to the solution below if you want):
If you are missing libva-drm.so.1 and/or libva-x11.so.1, you should note that there are no packages that provide those specific versions for ubuntu 18.04. The available versions are libva-drm.so.2 and/or libva-x11.so.2. Now, there is the package libva-dev, which provide libva-drm.so and libva-x11.so . I didn't install it, because if the versions wouldn't match, I would be in the same position: having an older version, or a newer one.
So I tried the following hack, with success: make symlinks (in the /opt/XnView/lib/ directory) to the available files. To put it simple:
If you are missing libva-drm.so.1 and/or libva-x11.so.1, enter this code in a console:
Assuming those where the only missing files in your system, as I had in my ubuntu 18.04 system, you should be done.
In my case, I did have a bit of strange behavior on the browser view (couldn't select files in detailed view) but I fixed it with this:
Settings -> Interface -> Recent files -> Purge now, and then restarted xnview. So far, it's working.
Edited on 15.09.2018 to add the following:
The above code doesn't affect any other thing than xnview; that's why the symlinks are done in XnView's directory.
If for any reason you would like to undo them, just enter this code to delete the two symlinks and get back to exactly how it was before:
The -i flag is just a simple precaution: it provides confirmation before deleting.
/opt/XnView/XnView: error while loading shared libraries: libva-drm.so.1: cannot open shared object file: No such file or directoryCode: Select all
/opt/XnView/XnView: error while loading shared libraries: libva-x11.so.1: cannot open shared object file: No such file or directoryI would like to contribute to help those who come to this thread and don't know what to do other than wait for the fix. This is how I made it work --at least for now.
WORKAROUND
cd /opt/XnView/lib/
sudo ln -s /usr/lib/x86_64-linux-gnu/libva-drm.so.2 libva-drm.so.1
sudo ln -s /usr/lib/x86_64-linux-gnu/libva-x11.so.2 libva-x11.so.1In my case, I did have a bit of strange behavior on the browser view (couldn't select files in detailed view) but I fixed it with this:
cd /opt/XnView/lib/
sudo rm -i libva-drm.so.1 libva-x11.so.1
xnviocumo
Hi Pierre,
I have just noticed that the XnViewMP-linux-x64.deb package currently in your download page is different than the one I downloaded and installed less than 20 hours ago. In fact:
1. downloaded today early in the morning:
md5sum: 994b4c2b44eac3be53dbe905be5c4d08
file size: 43.546.752
2. downloaded few minutes ago:
md5sum 3f112b50f73bd77cee2381f293f3a92c
file size: 44.215.802
Have you posted a new build? or could you please say what is the correct md5 checksum ?
If there would be two builds in use with the same version, that would be confusing. Perhaps if you would publish the build number, together with the download link, (and some hash, maybe md5 or better) that would be more transparent for downloaders what version do they have to download...
Thank you
Thank you
djcj
I agree. A revision could be helpful.xnviocumo wrote: Fri Sep 14, 2018 8:23 pm If there would be two builds in use with the same version, that would be confusing. Perhaps if you would publish the build number, together with the download link, (and some hash, maybe md5 or better) that would be more transparent for downloaders what version do they have to download...
Thank you
yes, with missing libraries
VictorVG
I checked the availability of libQtAVWidgets.so.1 in the tarballs for Linux x86 and Linux x64 - there is no file with that name in them. I did not get this error, but Dicinson with forum.ru-board.com has repeatedly asked a question about this.
Xeon E5 2697v2/C602/128 GB PC3-14900L Quad Channel/GTX 1660 Ti/9 Tb HDD
Xeon E5-2697v2/C602J/128 Gb PC3-14900L Quad Channel/GTX 1660 Ti/7Tb HDD
