i have a set of images and videos taken with a canon G7X, img are in jpg, plus some jpg + CR2 (raw), and videos are mp4.
I have an issue with the date and hour, i didn't update my time zone so i need to change hours on about half of pics and video by +1 or +2 hr, to be checked.
XnViewMP seems able to do that quite easily... i will check how...
But first, my video doesn't show the date in the column Date EXIF like for all jpg images, the correct date and time can be seen in thy details but it is not shown in the detailed list.
Is it possible to update also the videos date ? like i will do for the images ? +1hr or +2hr ?
The goal beeing to merge these img + vid with other images and videos taken with my mobile and have all of them sorted chronologically.
Regards,
Bernard
Date change (+2hrs) for img and video
Re: Date change (+2hrs) for img and video
For video files, you can only change file's date
