My English is very poor. I'm sorry
Thank you for your software. perfectly worked!
I found that the conversion can only take one image at a time and only one thread. There is also a queue when converting multiple files. Multiple other thread cores are idle.
I have to open more software at the same time to speed up the conversion.
So. Can you add features for multithreading to convert multiple pictures at the same time? Load one image per thread to maximize efficiency!
hope I am not dreaming.
Multithread efficiency improvement
Re: Multithread efficiency improvement
yes will be added
zhuanxu
