Make jpg file size larger
obelisk
I'm resizing some photos and they're studio so compress quite well. Even at 100% quality jpg it's 1.5mb. Low quality print supplier has a requirement that the file is certain MB, not res. How can I make this jpg larger without adding noise?
Re: Make jpg file size larger
To be clear, could the low quality print supplier possibly require a specified uncompressed size?obelisk wrote: Tue Sep 25, 2018 6:12 am I'm resizing some photos and they're studio so compress quite well. Even at 100% quality jpg it's 1.5mb. Low quality print supplier has a requirement that the file is certain MB, not res. How can I make this jpg larger without adding noise?
obelisk
I don't really know, but every now and then a cheap printer specifies files in mb instead of pixels. It's a sign to stay away but I can't control what people want to use
Perhaps I could save as bmp or tif, but being able to make huge jpg would also be a skill.
I've seen some people with 11mb jpg that if you open and save at 90% it's 2mb. I don't know how they make it huge.
In a specific case couldn't you clarify what the printer actually needs?obelisk wrote: Tue Sep 25, 2018 6:32 am I don't really know, but every now and then a cheap printer specifies files in mb instead of pixels. It's a sign to stay away but I can't control what people want to use![]()
But would they accept a format other than JPEG?Perhaps I could save as bmp or tif...
Maybe... But as you've said yourself, compressed size depends very much on the particular image.... but being able to make huge jpg would also be a skill.
obelisk
Yeah, if only they could listen. But they won't listen to me and what kinda crap printer doesn't understand res vs bytes
I suspect that they may really be interested in the pixel dimensions of images, which could relate directly to the way that they use the images... In that case you would probably need to downsample your images until the file size when saved uncompressed is as required.obelisk wrote: Tue Sep 25, 2018 7:40 am Yeah, if only they could listen. But they won't listen to me and what kinda crap printer doesn't understand res vs bytes
The size of the uncompressed file would be a direct measure of an image's pixel dimensions, I presume.
