Thumbnails small or blurry [0.92]
Tapio
Post by Tapio »
thx for XnView and XnConvert. With XnView MP, I am having problems with thumbnails. Often they are just too small and like upscaled from a tiny picture. But they are not tiny pictures. In the screenshot you see, it is png's with no thumbnail embedded. I am not using the thumbnail database.
Also, I did a "Recreate thumbnails" from the view-menu, on selections, selected files, it does not change. When I resice the thumbnail preview via the slider, it happens that they are displayed in just like 100x100 dimensions with just a big borders.
And you can see in the preview window that quality is decent.
Is there anyting I can do? Thx
Re: Thumbnails small or blurry [0.92]
In Settings>Catalog, which size do you have?
