XnView: MP 0.92 - 64 bit
OS: Linux
After "Save as", status bar shows file size of the saved image instead of the original file size.
1. Open an image in view mode. The status bar will show the file size of the image.
2. Use "Save as..." (the format doesn't matter)
3. The status bar now shows the file size of the saved image rather than the original.
0.92: After "Save as", status bar shows file size of the saved image
Daniel710
Re: 0.92: After "Save as", status bar shows file size of the saved image
not really a bug, currently after save as, filename is replace by new one
i'll add a setting
i'll add a setting
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
