Subject: 0.92: Keyboard inactive in list view mode
XnView: MP 0.92 - 64-bit
OS: Windows 7 - 64-bit
Effect:
Unable to navigate through the file list with the keyboard arrows
1. Browse a folder with some image files
2. Make sure you are in list mode display in the right panel
3. Try to navigate through the files using the arrows on the keyboard...
Actual behaviour (bug): The keyboard doesn't work!
Expected behaviour: It is possible to navigate through the list of files using the keyboard
0.92 - Keyboard inactive in list view mode
merlinpimpim
