Using .xbs files saved from XnView Classic
Kirr
Post by Kirr »
I'm using XnView Classic for a long time. Today I gave a try to MP, primarily for its Curves tools and more powerful Adjust tool. And I must say MP seems to be very cool! (it was not intended to be rhymed :D )
One issue I've got for now is one with Batch convert presets (.xbs).
The formats of Classic and MP xbs-files are obviously different: Classic files have simple line-by-line textual format while MP files have xml format.
On the other hand, If I select Classic xbs for import in Batch convert dialog the import works but only a small part of saved params are restored.
What's with this thing? Is this a bug? Or Classic xbs is not planned to be supported? (not a horrible option though)
Regards!
Re: Using .xbs files saved from XnView Classic
which params are not restored?
Kirr
Post by Kirr »
It looks like only Actions are restored. Not flags, nor JPG quality.
Additionally, if the actions are Brightness and Contrast then they are restored as two full Adjust (Brightness-Contrast-Gamma) actions. This is understandable as for import behaviour but looks quite weird.
Regards!
Kirr wrote: Wed Oct 24, 2018 5:42 pm It looks like only Actions are restored. Not flags, nor JPG quality.
yes currently only actions are restored
yes all "classic" actions are imported as 'MP' actions
Kirr
Post by Kirr »
Ok.
Thank you for clarifying! :)
