a1: Create > Create Contact sheet
The menu "Create" is quite good, I think. Sure enough the word "Create" or "Generate" in all menu items should be removed (in all languages). But that's probably something for the Beta testing and the translators...
Re: Create > Create Contact sheet
Yes righthelmut wrote:The menu "Create" is quite good, I think. Sure enough the word "Create" or "Generate" in all menu items should be removed (in all languages). But that's probably something for the Beta testing and the translators...
In beta1, this is almost solved. We still have "Generate File listing". "Create > File listing" may sound a little bit strange, but "Create > Generate File listing" does not make sense.xnview wrote:Yes righthelmut wrote:The menu "Create" is quite good, I think. Sure enough the word "Create" or "Generate" in all menu items should be removed (in all languages). But that's probably something for the Beta testing and the translators...
