Stalled while scanning a folder [Solved]
Y-Phil
Post by Y-Phil »
Hi
First: thanks for that fantastic tool, numerous years-long fan :D
That being said, I have a folder, containing 203 files, and XnView MP Windows 0.88 64 bits portable version locks down on one file.
The only way to get out is the task manager.
Is there an easy way to detect which file it doesn't "like"? :)
Thanks in advance
Y-Phil
Re: Stalled while scanning a folder
do you have tried with lastest version? Which format do you have in this folder?
Y-Phil
Post by Y-Phil »
Hi
"Which format do you have in this folder"... you gave me the response!
I've discovered a 686Mb video... wow
Removed... Problem solved...
Sorry for the wrong problem.
My God, I should have thought to such a simple detail :shock:
Thank you! :D
