Categorisation seems to be gone
leiper
I have categorized a number of pictures. Suddenly when I started Xnview some are gone from Categiries Filter... e.g. one categorie says that there are 5 marked pics, but only 3 show up when I choose that one. Just in the moment I click, the other two glimpse up (not always I think). Is there any way to recreate or refresh it so marked pics and number correspond and all marked pics really show up. For the moment it feels a litte unsecure to use this function! /Leif
Re: Categorisation seems to be gone
do you use XMP metadata?
leiper
I´m using Categories and have made some new ones. But some pics seems to have disappear from a category but the number of pics is still there, so it don´t match - number and amount of showed pics in the category
but do you export categories into XMP metadata?
leiper
No, is that supposede to be done? I have used Categories from the UI and that looked good at first time...
If you have not use embedded metadata, you can't recreate categories hierarchy.leiper wrote: Fri Nov 30, 2018 2:38 pm No, is that supposede to be done? I have used Categories from the UI and that looked good at first time...
Please send me your xnview.db, and tell me which files/categories have problems
leiper
Where to attach files?
i've sent a PM
