Sending an image from XnView MP (Linux) to a programme running in WINE
pseudopanax
Post by pseudopanax »
On my Ubuntu 18.04 installation, I can successfully send images from Rawtherapee to a WINE application (e.g. Nik collection) using the following command syntax in Rawtherapee's External Editor/Custom Command Line: "/usr/share/playonlinux/playonlinux --run "Viveza 2" %F"
I have tried to use the same command (with and without quotes) in XnView MP's Tools>Open With menu without success. Has anyone else tried this at all?
Re: Sending an image from XnView MP (Linux) to a programme running in WINE
and with
pseudopanax
Thanks for the reply. I did try that and I also tried exec=/usr/share/playonlinux/playonlinux --run "Viveza 2" Neither work unfortunately.
Wayne
if you start XnViewMP from a terminla, do you have a message when you use 'open with'?
pseudopanax
yes, the following:
Edit: I've replaced my user name with USER for this post
Script started, file is /home/USER/Pictures/TiFF/2018-11-13_IMG.JPG
USER@USER-OptiPlex-3020:~$
############################################ onTimerDirectoryChanged 1
######## checkChildren
############################################ onTimerDirectoryChanged ok
Edit: dragging and dropping from XnView onto the desktop icons for the WINE apps works fine
with non Wine app, no problem?
pseudopanax
no problem with native linux apps.
Wayne
pseudopanax
changing the command to: playonlinux --run "Viveza 2" %f
opens the app OK, but not the file. I tried changing the argument to tell the WINE app to look in the Z drive for the file but without success. It's not a big issue though because as I mentioned below, I can simply copy the file to the desktop from XnView MP and then drag and drop the file onto the appropriate Nik Collection desktop icon.
