When a file is saved as in save as the file is saved OK but when opening the image it is very small. How do I save the file to get a full size image on opening?
Thank you
Displayed size of a file
Re: Displayed size of a file
When a file is opened, the size of an image on the screen depends on several factors:
The option set in View > Auto image size
The image pixel dimensions
And for some file formats, the setting used in File > Format settings... > Read tab
If you still have a problem after reviewing those settings, please give more details or if possible upload an example file.
