When toggling the slideshow with the toolbar icon, the change is very, very slight - the icon itself doesn't change, it just gets a tanslucent bump. I dunno if it's only me, but I can never really tell if the slideshow is active - esp. with long slide times.
=> Please add a different on/off icon, or at least a much more visible bump or other change (bright/dark, ...)
Slideshow icon on/off more visible
Re: Slideshow icon on/off more visible
the background of icon change like any other toolbar button
Marsu42
Thanks.
There is a similar longtime-bug after moving (and maybe copying) a file, i.e. the left/right key navigation doesn't work anymore any you have to reopen the tab to make it work again. But I cannot give a description how to reproduce it yet, but maybe you have a idea anyway what the problem could be. Otherwise I'll keep trying to come up with steps how to reproduce this bug.
