9 suggestions/bugs (exif, navigation)
Alexey Lubkin
Post by Alexey Lubkin »
exif:
1. Exposure time is always looks like "10/600", but should "1/60" instead.
2. Focal length is always looks like "50.0000". Why not just "50" ?
3. One unable to use most important exif tags which is displayed at the bottom of metadata list (Alt+Enter -> EXIF). For example, Nikon-D70's exif the "ISO Value" is placed only in the bottom part of the list (called "ISO Setting"), so I can't use it to make(=format) information string (Options->View->Fullscreen->Show Information).
4. "F-Number" tag returns something like "F2.8", but should "2.8" instead.
5. It would be awesome, if EXIF window would be a non-Modal window (for Browser-mode), so one can always watch EXIF data just by clicking on the thumbnail.
6. The <Size> tag returns size in bytes in the way like "1189701", which is too heavy to read. The string like "1 189 701" would be much better.
faster navigation:
7. It would be nice to have ability in Fullscreen-mode to make image fit the screen just by pressing some key.
8. For now the only way to navigate between the tabs (in Browser-mode) is to press Ctrl+Tab or Ctrl+Shift+Tab combinations. I think, All+1, Alt+2, Alt+3, ... - is much better.
9. It have sense to make ability to open current image with favourite editor just by pressing some key combination.
Thanks, Alexey.
Upd: Sorry, I have no rights to delete this topic. All theese suggestions were divided by 6 new topics.
Dreamer
Post by Dreamer »
<Moderator's note: Please start a new topic for each suggestion/question - see Rules & Guidelines>
Please don't reply here, thanks.
Thank you, Alexey, for splitting up your post. With individual posts you will get more and better replies. A moderator will delete this topic later.
