[Fixed] Another crash, when I switch to any multipage ico
Locked
Dreamer
Post by Dreamer »
Another crash, when I switch to any multipage ico file in Viewer.
More info:
AppName: xnview.exe AppVer: 1.82.0.0 ModName: kernel32.dll
ModVer: 5.1.2600.2180 Offset: 0000a258
Re: Another crash, when I switch to any multipage ico file
Dreamer wrote:Another crash, when I switch to any multipage ico file in Viewer.
More info:
Strange, do you have the version (Nov 1 2005)??
Dreamer
Post by Dreamer »
More info:
Fixed in v1.82 Nov 1 2005. :)
Roytam1
Post by Roytam1 »
crash revisited.
AppName: xnview.exe	 AppVer: 1.82.0.0	 ModName: xnview.exe
ModVer: 1.82.0.0	 Offset: 000c7c13
Exception Information
Code: 0xc0000005	Flags: 0x00000000
Record: 0x0000000000000000	Address: 0x00000000004c7c13
Dreamer
Post by Dreamer »
Roytam1 wrote:crash revisited.
In v1.82 Nov 1 2005?
Roytam1
Post by Roytam1 »
yes.
Sample ?
:arrow: Roytam1
:) Hello !
- I use the same Alpha and I can't reproduce this crash under XP-Pro.
- Which multi-page icon(s) are you testing ? Mine is one I built with XnView 1.80.3. under Win 98 SE a while ago…
- Maybe could you provide us a file-sample, 'cause the file itself could be out the norms (or damaged) ?
:mrgreen: Kind regards,
Roytam1
Re: Sample ?
Post by Roytam1 »
Clo wrote::arrow: Roytam1
:) Hello !
Oops. It should be in Thumbnail mode but not in icon mode.
Icon mode works gracefully in Nov 1 build.
Sorry.
It crashes when going to parent folder in Thumbnail mode.
Dreamer
Re: Sample ?
Post by Dreamer »
Roytam1 wrote:Oops. It should be in Thumbnail mode but not in icon mode.
Sorry.
It's another (known) bug.
Same
:arrow: Roytam1
:) Hello !
- Coming back to the parent folder and even to the drive-root in the browser doesn't crash here…
The issue is known, but the problem itself still persists, right?
(The "[Fixed]" in the topic title is a bit irritating, this is why I'm asking).
Dreamer
Post by Dreamer »
helmut wrote:The issue is known, but the problem itself still persists, right?
This topic is for "switch from one image to another in viewer = crash" - this bug has been fixed, therefore "[Fixed]".
There is another bug "Crash when browsing in thumbnails mode, with "4 images&" - NOT fixed.
Locked
