0.92 - Can't hide menu bar
CreativeWorld
Post by CreativeWorld »
XnView: MP 0.92 - 64-bit
OS: Windows 10 - 64-bit
Can't hide the menu bar. I've tried adding:
[Hidden]
MenuBar=1
to the INI file but it doesn't work.
Re: 0.92 - Can't hide menu bar
sorry but there is no way to hide menu bar
macabong
Post by macabong »
You can try BorderlessGaming freeware (https://github.com/Codeusa/Borderless-Gaming/releases)
Launch the software:
Add Xnview to Favorite using Regex or anything that works
Right-click xnview > Remove Menus
Right-click xnview again > No Size Change then Set Windows Size
this step you can either draw a visible window first to see the available area or fine tune the coordinates by selecting "Set Window Size" again and answer "no" to the prompt.
For my 4K tivi my coords are 50, -20, 3856, 2160. This way only half menu will show enough to read/click; smaller scrollbar on the side, and no tittle bar. then ctrl+f10 to hide the filelist toolbar if needed.
