[Solved] Files on alternate partition (UBUNTU)
Jacques-64
Post by Jacques-64 »
I recently switched from Windows to Ubuntu (and so from XnView Classic to MP). On my computer I had 2 partitions : system & Data. With Ubuntu, a 3rd partition was created (called "Comptuter" when I want to open a file.
I don't find any way to open files located in System or Data, only thuse on "Computer". Can anyone tell me how I can do that ?
Thanks a lot and whish you a heapy new year
Jacques
[Edit] Running XnView MP Linux Version 0.90 64bits (Mar 5 2018)
Find the solution : other drives are on sub-dir of "Media". Using file navigator, they appeared directly and that is source of my confusion [/Edit]
