What is the correct definition for gflAddText in delphi??
haerdalis
Post by haerdalis »
All the ones I have tried totally ignores the color parameter,
and instead writes the text with total transparency.. even after
changing the TGFL_COLOR structure to the same as defined in
libgfle.h.
By the way, it seems like the libgfl.pas hasn't been updated in a while.
I've tried:
function gflAddText(src: PGFL_BITMAP;
text: PChar;
font_name: PChar;
x: GFL_INT32;
y: GFL_INT32;
font_size: GFL_INT32;
orientation: GFL_INT32;
italic: GFL_BOOL;
bold: GFL_BOOL;
strike_out: GFL_BOOL;
underline: GFL_BOOL;
antialias: GFL_BOOL;
var color: PGFL_COLOR): GFL_ERROR; stdcall;
text: PChar;
font_name: PChar;
x: GFL_INT32;
y: GFL_INT32;
italic: GFL_BOOL;
bold: GFL_BOOL;
var color: TGFL_COLOR): GFL_ERROR; stdcall;
and
text: PChar;
font_name: PChar;
x: GFL_INT32;
y: GFL_INT32;
italic: GFL_BOOL;
bold: GFL_BOOL;
const color: PGFL_COLOR): GFL_ERROR; stdcall;
Re: What is the correct definition for gflAddText in delphi?
haerdalis wrote:What is the correct definition for gflAddText in delphi?
libgfle.h.
text: PChar;
font_name: PChar;
x: GFL_INT32;
y: GFL_INT32;
italic: GFL_BOOL;
bold: GFL_BOOL;
This one doesn't works??
haerdalis
Post by haerdalis »
libgfle.h.
text: PChar;
font_name: PChar;
x: GFL_INT32;
y: GFL_INT32;
italic: GFL_BOOL;
bold: GFL_BOOL;
Well, no, not really.. In RGB or similar without alpha, yes then it works, but not in RGBA mode, or the other alphamodes.. Then it writes the text in the same color as the
main background is instead.. Rather strange actually..
haerdalis wrote:Well, no, not really.. In RGB or similar without alpha, yes then it works, but not in RGBA mode, or the other alphamodes.. Then it writes the text in the same color as the
Ok, i'll check
