Hello!!
I have the last version of XNVIEW, windows 64bit.
when i open any image, just double click, xnview appears with my image in the screem... but when i double click to an .ecw file.. xnview just open the explorer tab.. and nothing more..
when i open any image (like jpg or png) in the same folder that a ecw file, i can view passing image by image.. and i can opening from the explorer tab... but no form windows explorer...
any solution?
Thanks a lot.
opening .ecw file just open explorer tab
luiscuadrado123
Re: opening .ecw file just open explorer tab
it seems that there is a problem in registry with your .ecw association, please check
luiscuadrado123
with regedit tool
luiscuadrado123
i found that Infrantview open that type of files fine.
thanks for your help
