[v0.93] Numerous crashes in Browser Mode (Mac)
Henry-In-Florida
I uploaded various crash reports that occurred while opening and scrolling media files in the latest XnViewMP (0.93). Most happen when scrolling through a large-ish catalog >1000 images, while previewing some of the images. I started from scratch with a new install (not a migration from previous version).
Henry
Henry-In-Florida
Computer Equipment: MacBook Pro 2017 Touch Bar, 8GB RAM, Mojave (10.14.2), 250GB Internal SSD; on a Desktop with Dual Dell External Displays
External Storage: SSD RAID 1.5TB, 500GB SSD (via T3)
XnViewMP 0.93
Henry-In-Florida
XnViewMP 0.93
Re: [v0.93] Numerous crashes in Browser Mode (Mac)
do you have sent the crash dump?
Henry-In-Florida
Not sure, they may have gone only to Apple. I found the Crash Reporter logs in my system. However, in the interim, I got an email from Pierre-e Gougelet noting the report and that I need to upgrade to 0.93. It seems that somehow in the process of the upgrade and starting from scratch, I was still using the older 0.92 version at some time during the crashes (maybe all the time?). So I made sure that I upgraded today and using 0.93.
Do you still want the logs anyway??
Henry
Henry-In-Florida
XnViewMP 0.93
Henry-In-Florida
XnViewMP 0.93
Henry-In-Florida
I see it is you, Pierre. I did file. In case you haven't gotten them, cannot attach them unless I zip them. So two folders zipped up- Crash Reporter folder of 1 file, Archive of Logs folder with 5 files related to XnViewMP.
Also made separate forum bug reports about the failure/anomalies in both Full Screen and Dual Monitor configuration/setting performance.
Regards,
Henry
Henry
Henry-In-Florida
XnViewMP 0.93
Henry-In-Florida
XnViewMP 0.93
Please use the crash dialog to upload them, and set your username as info...Henry-In-Florida wrote: Sun Feb 03, 2019 12:15 pmI see it is you, Pierre. I did file. In case you haven't gotten them, cannot attach them unless I zip them. So two folders zipped up- Crash Reporter folder of 1 file, Archive of Logs folder with 5 files related to XnViewMP.
Henry-In-Florida
Where is it, in XnView?xnview wrote: Sun Feb 03, 2019 12:54 pm Please use the crash dialog to upload them, and set your username as info...
Henry
Henry-In-Florida
XnViewMP 0.93
Henry-In-Florida
XnViewMP 0.93
you have not a dialog 'XnView crash reporter' opened when you have the crash?Henry-In-Florida wrote: Sun Feb 03, 2019 1:46 pmWhere is it, in XnView?xnview wrote: Sun Feb 03, 2019 12:54 pm Please use the crash dialog to upload them, and set your username as info...
Henry-In-Florida
Of course, that is what I used! I only posted here since there was no feedback about it over a few days.xnview wrote: Mon Feb 04, 2019 1:02 pm you have not a dialog 'XnView crash reporter' opened when you have the crash?
Henry
Henry-In-Florida
XnViewMP 0.93
Henry-In-Florida
XnViewMP 0.93
could you re-send it again, and please put your username in the text fieldHenry-In-Florida wrote: Mon Feb 04, 2019 4:28 pmOf course, that is what I used! I only posted here since there was no feedback about it over a few days.xnview wrote: Mon Feb 04, 2019 1:02 pm you have not a dialog 'XnView crash reporter' opened when you have the crash?
are you able to send a crash report via the dialog?Henry-In-Florida wrote: Mon Feb 04, 2019 4:28 pmOf course, that is what I used! I only posted here since there was no feedback about it over a few days.xnview wrote: Mon Feb 04, 2019 1:02 pm you have not a dialog 'XnView crash reporter' opened when you have the crash?
jadO
Do you see crashes only or freezes as I am also seeing more freezes with 0.93 while scrolling media.Henry-In-Florida wrote: Sat Feb 02, 2019 12:18 pm I uploaded various crash reports that occurred while opening and scrolling media files in the latest XnViewMP (0.93). Most happen when scrolling through a large-ish catalog >1000 images, while previewing some of the images. I started from scratch with a new install (not a migration from previous version).
