Not sure if these are 0.93 regressions...
1) The batch converter loses some settings every time I open it.
e.g. JPEG Format settings.
I have to re-load my Batch Convert preset again, every time now.
2) Create a New Folder (from within XNV-MP) and start typing a name. It doesn't delete the 'New Folder' name, as it should. It just adds to it.
0.93 regressions?
Re: 0.93 regressions?
could you describe the steps to reproduce?Evan wrote: Mon Feb 04, 2019 1:16 pm 1) The batch converter loses some settings every time I open it.
if you create a new folder in thumbnail view?2) Create a New Folder (from within XNV-MP) and start typing a name. It doesn't delete the 'New Folder' name, as it should. It just adds to it.
Evan
1) To reproduce...
Create a preset in the batch converter. Make sure you change the JPG settings also... (Quality, Optimize Huffman table, DCT Method etc...)
Save preset.
Select images in thumbs view, right click, choose batch convert.
JPG settings are back to default.
Load your preset.
JPG settings are loaded OK.
Close batch convert.
Reselect thumbnails and reopen Batch Convert via right-click menu.....
Result: Some settings in the Batch converter are persistent (e.g. Actions panel). Some are reset. Like the JPG options (which is also a little troubling since you need to open the JPG settings to find out)
Desired outcomes and FRs:
- Allow to persist either all settings, including JPG formats, or no settings.
- Preferably, persist all previous settings, with an option to reset to defaults (either globally, or per Tab would be perfect)
2) Yes I am talking about the thumbnails view.
Hope this helps.
Save preset.
Load your preset.
Hope this helps.
It was like that in 0.92 too. If you don't load your preset, it can't be restored. By default, Settings>Formats persistEvan wrote: Tue Feb 05, 2019 7:43 am 1) To reproduce...
Save preset.
could you send me screenshots, i don't understand the problem?2) Yes I am talking about the thumbnails view.
