I've got a original scan-picture with 48 bit color depth, these should turned and cropped.
But after processing I've got as result a picture with 24 bit instead of 48 bit color depth.
How can I prevent this?
pvpp
How can I prevent a reduction of color depth?
Re: How can I prevent a reduction of color depth?
XnView only use 8bits per component as internal data
pvpp
OK, thanks
pvpp
pvpp
