0.93: libstdc++ relocation error
Daniel710
Post by Daniel710 »
XnView: MP - 64 bit
OS: Linux, Xubuntu 14.04, 64 bit
XnView doesn't run after upgrading from 0.92 to 0.93. The error is:
/opt/XnView/XnView: relocation error: /opt/XnView/lib/libQt5WebKit.so.5: symbol _ZTVNSt7__cxx1115basic_stringbufIcSt11char_traitsIcESaIcEEE, version GLIBCXX_3.4.21 not defined in file libstdc++.so.6 with link time reference
Re: 0.93: libstdc++ relocation error
XnView is now built on ubuntu 16.04, you can try the appimage package
Daniel710
Post by Daniel710 »
The AppImage gives exactly the same error:
/tmp/.mount_XnViewgrmN1x/usr/XnView/XnView: relocation error: /tmp/.mount_XnViewgrmN1x/usr/XnView/lib/libQt5WebKit.so.5: symbol _ZTVNSt7__cxx1115basic_stringbufIcSt11char_traitsIcESaIcEEE, version GLIBCXX_3.4.21 not defined in file libstdc++.so.6 with link time reference
and by installing
sudo apt-get install libstdc++6
Daniel710
Post by Daniel710 »
It's already installed. Maybe the AppImage was also built on Ubuntu 16.04?
Daniel710 wrote: Tue Feb 05, 2019 2:58 pm It's already installed. Maybe the AppImage was also built on Ubuntu 16.04?
yes
