Hello, I'm just playing around with the catalog functions. I am missing a filter function for the categories. I can filter the complete catalog by category, but unfortunately not a certain folder. Did I overlook something?
If not, it would be great if this function existed. So a filter possibility in a folder according to categories. Just like it works with the ratings.
Cheers
Frank
Category filter
Re: Category filter
Above the Categories Filter, you have a "Match" menu. Click on the arrow and you will find your happiness.
Sirio
Re: Category filter
Thank you, I found it!!! I simply overlooked it!
