XnView MP Windows
Version 0.93 64bits (Jan 31 2019)
Libformat version 7.25
Windows 10 64bit
There is probably a bug in the Targa (.tga) file format loading code for 16-bit TGAs that are compressed with RLE (runtime-length-encoding). I have attached a picture where the bug occurs.
If you load the picture with XnView MP and zoom in, you can see that the last pixel row is moved to the left by one. If you load the picture in a different program, it is correctly loaded.
XnView (without MP) may also be affected since its visible in a program called "SageThumbs" which seems to use XnView.
The TGA was created with Photoshop.
Bug in TGA decoding
Katharsas
Bug in TGA decoding
Re: Bug in TGA decoding
This problem is supposed to be fixed in XnView MP 0.93.1. Please check and confirm the bug fix here.
Katharsas
Seems like its fixed. Thanks : )
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
