Support for HEIC
Soban
Support for HEIC
Post by Soban »
Hello, do you plan to add Apple's HEIC format support?
Marsu42
Re: Support for HEIC
Post by Marsu42 »
It's supported on Mac with 0.93.1: https://www.xnview.com/mantisbt/view.php?id=1566
Btw the heic "format" is a subset of heif - so supporting this (with built-in free codec implementation and external mpeg) probably is the way to go: viewtopic.php?f=60&t=38649
Soban
Post by Soban »
Marsu42 wrote: Fri Mar 08, 2019 10:57 am It's supported on Mac with 0.93.1: https://www.xnview.com/mantisbt/view.php?id=1566
On macOS it’s normal that I can open heic
I meant support for windows version of xnview
Please check Plugins
