New hotkeys/shortcuts
Dreamer
Is it possible to add some hotkeys/shortcuts to v1.82? Some would very useful and maybe easy to implement. Could you check this (updated) list please?
XnView 1.82 -
XnView 1.82 -
Re: New hotkeys/shortcuts
Ok, i'll tryDreamer wrote:Is it possible to add some hotkeys/shortcuts to v1.82? Some would very useful and maybe easy to implement. Could you check this (updated) list please?
About "Show/Hide Folder Tabs - Ctrl+Shift+M" there is alreayd a shortcut Ctrl+shift+F
Dreamer
No, it's folder tree, not folder tabs.xnview wrote:About "Show/Hide Folder Tabs - Ctrl+Shift+M" there is alreayd a shortcut Ctrl+shift+F
So it's tabsDreamer wrote:No, it's folder tree, not folder tabs.xnview wrote:About "Show/Hide Folder Tabs - Ctrl+Shift+M" there is alreayd a shortcut Ctrl+shift+F
Mulder
auto levels and contrast
I agree. Thanks for adding automatic levels and contrast into nconvert (and thus batch processing), but hotkeys would be very usefull too. And for 'equalize' too please.
I know that there are many hotkeys now, but isn't it time to add customizable hotkeys for all menu items? I know it isn't easy to do it, but ...
Dreamer
Re: auto levels and contrast
You can support this request - Custom Hotkeys / Shortcuts.Mulder wrote:...I know that there are many hotkeys now, but isn't it time to add customizable hotkeys for all menu items? I know it isn't easy to do it, but ...
Xyzzy
What about solving this problem once and for all?
A new Options page with list view and a few buttons.
The list contains avaliable actions and their assigned shortcuts. User clicks an item, input field below activates with text 'Click here and enter shortcut'. There there is Accept button, a few message dialogs to add, nothing serious.
And mile lenght threads about what to assign to what action are all gone.
Shall I design this feature?
X.
X.
Yes, but i can't add it now in 1.82Xyzzy wrote:What about solving this problem once and for all?
Tommy
