Some thumbnails are not correctly oriented
Chris
Post by Chris »
I have just downloaded XnView. Thank you for this freeware!
I noticed a few CRW files (from my Canon 300D) are not correctly oriented and should be turned 90 degrees to the left whereas they are correctly oriented in Adobe Bridge.
Also, in the Properties they are said to be from a Canon PowerShot instead of a 300D.
Are there parameters I should change?
Thank you for your help
Re: Some thumbnails are not correctly oriented
Chris wrote: I noticed a few CRW files (from my Canon 300D) are not correctly oriented and should be turned 90 degrees to the left whereas they are correctly oriented in Adobe Bridge.
Perhaps you could send me a sample?
Chris
Post by Chris »
You mean send you an image? How can I do that? I could not find a link to upload...
Chris wrote:You mean send you an image? How can I do that? I could not find a link to upload...
Yes by email: [email protected] (remove -nospam)
