0.93.1 Space key is completely ignored
Bisasam
Post by Bisasam »
XnView: MP 0.93.1 - 64 bit
OS: Linux (Kubuntu) 64bit
Before, I always used the space key to switch to the next picture. This always worked... until now.
Now, the Space key is completely ignored and can't be used anymore.
In the shortcut settings, "Space" used to be set to "cmd_fileNext". Now "cmd_fileNext" is set to nothing.
On the next tab, "Keyboard", there's a new setting called "Space", which is set to "Next file". Apparently though, this doesn't work, as the space key does absolutely nothing.
I already tried setting the space key for "cmd_fileNext", as it was before, but that doesn't do anything either.
I'd call this a major annoyance.
Effect: You can't use the space key anymore to switch to the next picture.
1. Press the Space key.
Actual behaviour (bug): The Space key, it does nothing! :bug:
Expected behaviour: The Space key switches to the next image.
As this is a great loss in functionality for me, I'll be switching to the previous version, until this is fixed.
Re: 0.93.1 Space key is completely ignored
now SPACE key is configured in settings>Interface>Keyboard
