Two bugs with zooming
Lee James
Post by Lee James »
(These bugs have been present for a while now…)
I use right mouse button + scroll wheel to zoom.
1.
Problem: When I release the right mouse button, the context menu often appears.
Solution: Context menu should not appear following a zoom.
2.
Problem: After I press down the right mouse button, if I accidentally move the cursor slightly before scrolling the wheel, the dimensions of a selection appear.
Solution: If scroll wheel is used while right mouse button is held down, dimensions should disappear.
Re: Two bugs with zooming
Lee James wrote: Mon Mar 25, 2019 4:08 pm Problem: When I release the right mouse button, the context menu often appears.
Why do you use right mouse button + wheel to zoom?
I can't reproduce
Lee James
Post by Lee James »
xnview wrote: Mon Apr 15, 2019 1:43 pm Why do you use right mouse button + wheel to zoom?
Because I want the scroll wheel to move to the previous/next file.
Or, if you're asking why I use the right button instead of the left button, because using the left button would require me to use my middle finger to scroll, which I have never done and would seem totally wrong to me.
I can't reproduce
You need to have the right mouse button set up to control zoom selection.
