Processing does not work?
Elk
Post by Elk »
When I process an image with these settings
thhis is shown after:
But there is not even a new file, no new file saved / compressed or such.
What might be wrong?
Re: Processing does not work?
no file in output folder?? and if you change it?
Elk
Post by Elk »
Cannot find any new file / image. In no folder. With the classic Xnview it works.
could you try to use 'JPEG' instead of 'JPEG guetzli'?
Elk
Post by Elk »
Yes, that works. Why does it not work with the other one?
When I switch bewtween the profiles the "Format" keeps staying the same? Is it like it should be? I wanted when I open a profile that the format I assigned to the profile would be set.
Elk wrote: Wed Mar 27, 2019 2:05 pm Yes, that works. Why does it not work with the other one?
There is some limitation of pixels size with jpeg Guetzli
could you send me it?
Elk
Post by Elk »
Cannot upload it here in the forum obvioulsy, so here is its content:
<?xml version="1.0" encoding="UTF-8"?><XnView_script version="1.0" name="50%,NoExif,800x600">
    <Resize mode="0" width="800" height="600" unit="0" ratio="true" orientation="false" enlarge="0" resample="7" gamma_correct="false"/>
    <Output folder="I:/Bild-Ausgabe/Komprimiert" filename="{Filename}-#" case="0" startIndex="1">
        <Options overwrite="1" orgDate="false" keepMeta="true" keepICC="false" keepFolder="false" keepParentFolder="false" keepExtension="true" delOrg="false" multipage="false" allPages="false" openExplorer="false" openBrowser="false" clearItems="false"/>
        <JPEG quality="50" progressive="false" optimizeHuffman="false" rebuildThumb="true" orgQuality="false" DCTMethod="0" subSampling="0" smoothFactor="0"/>
        <TGA compress="false" bottomUp="false"/>
        <TIFF compress="0" quality="80" compressBW="0" oneStrip="false"/>
        <BMP compress="false" hdrOS2="false"/>
        <PNG level="6" interlaced="false" filter="0"/>
        <GIF interlaced="false" hdr87a="false"/>
        <PCX compress="false"/>
        <WEBP method="0" quality="80" filesize="128" compress="4" strength="60" sharpness="0"/>
        <GUETZLI/>
        <JP2 mode="0" quality="80" ratio="4" fileSize="100"/>
        <PDF compress="0" compressGrey="0" compressBW="0" quality="80"/>
        <JXR quality="80" colorFormat="0" filter="0"/>
    </Output>
</XnView_script>
this xbs was saved by XnViewMP?
Please change in the .xbs
<Output folder="I:/Bild-Ausgabe/Komprimiert" filename="{Filename}-#" case="0" startIndex="1" format="JPEG">
