"Open with" and Microsoft Store Apps
dergilbwillspam
Post by dergilbwillspam »
Hi all,
I want to open Paint.NET from the Microsoft Store with a shortcut within XnView MP to edit images. But since linking to the .exe doesn't work with these apps, I had to build a batch file as a workaround.*)
Now this has two (very minor, but still) downsides:
  1. The cmd window flashes up.
  2. There's no icon in the "Open with" list.
Is there a "nicer" way to do this?
*) It's:
@start paintdotnet:%*
Re: "Open with" and Microsoft Store Apps
not sure that you have an easiest way
dergilbwillspam wrote: Tue Apr 23, 2019 10:30 pm I want to open Paint.NET from the Microsoft Store with a shortcut within XnView MP to edit images. But since linking to the .exe doesn't work with these apps, I had to build a batch file as a workaround.*)
*) It's:
xnview wrote: Fri Apr 26, 2019 11:09 am not sure that you have an easiest way
Surely you could download the program directly from https://www.getpaint.net/ and configure the XnView shortcut the normal way?
dergilbwillspam
Ok. If I think of something, I'll post it here.
dergilbwillspam
cday wrote: Fri Apr 26, 2019 11:22 am Surely you could download the program directly from https://www.getpaint.net/ and configure the XnView shortcut the normal way?
Surley I could, but that wasn't the question now, was it.
