Some image formats show icons not thumbnails
kirbyspencer
Post by kirbyspencer »
I have Settings/Genera/Display All Formats checked but not all images are displayed. In particular AI files, most PSD files, EPS and PDF. The files are for the CS6 version of AI and PS.I'm on an iMacPro running Mohave 10.14.4.
This is a great program, very fast, very flexible, I was happy to pay for it.
Attached are two JPEGs showing the problem.
Rick
Re: Some image formats show icons
Post by Rick »
I am not the go-to guy on these issues but a lot of it depends on the publisher of the file format and if they allow for a thumbnail and how they have it configured. I am using Serif Affinity products and the thumbnail used to show but due to a change in the beta, it does so no longer
I will take correction on this but I am not sure it is an XnView problem not is it something that they can fix
Rick
You both have Ghostscript installed?
From the XnView Wiki :
"Ghostscript is open-source software which enables XnView and related programs to load PostScript-based file formats (PS + EPS + AI) as well as PDF for display, printing, and conversion."
Thumbnails may be another issue, of course.
kirbyspencer
Re: Some image formats show icons not thumbnails
I do not have Ghostscript installed, I guess I'll look into that but AI is a very common file format. My expectation is that it would be supported.
kirbyspencer
Wow, thank you, I installed Ghostscript 9.27, did a restart of XnView and it worked!
