I suggest that when using timed slideshow, you add an option to pause the slideshow with spacebar. Optionally add a "pause" background and/or image.
When user would pause the slideshow, it would not only stop the slides but also display a black background for example (or some cool image). On resume, the background/image disappears and slideshow normally continues.
Slideshow suggestion
