When created multipage file is saved open destination folder
gegemon2012
Post by gegemon2012 »
Hello!
Is it possible to add the ability to automatically open the destination folder in Explorer where the created multipage PDF file is saved? Since I often save files it would be very convenient to have such a function. Or is this feature already available and I just did not find it?
Re: When created multipage file is saved open destination folder
gegemon2012 wrote: Fri May 24, 2019 12:55 pm Is it possible to add the ability to automatically open the destination folder in Explorer where the created multipage PDF file is saved? Since I often save files it would be very convenient to have such a function. Or is this feature already available and I just did not find it?
XnView MP, the new cross-platform software with Unicode support and also available in a 64-bit version, already supports that option:
Not sure about XnView Classic, but probably not if you are requesting it!
gegemon2012
Thanks for fast answer!
